So how do I stop programs from running all the time? I have some like a Bible and some other things that always seem to be running. Then there's things like email, uploads, play store, etc that seem to run for no reason. I've used task killers but if I kill there then go to super box for example it's still running there. It's like each killer just kills it in its screen.after killing it it will start up again a few minutes later....any help. Side question, what can I use to get CD art if I rip a CD to a comp then to my phone and it doesn't have CD art and titles. Is there a music player that does that. Sorry about the long post
ill talk about you music first,if you have music on you phone and you want the cd image to appear as well, just put the music in a folder with the image inside it as well, the stock music player will show the images, idk if the 4x1 size stock music player will, 4x2 and fullscreen will tho
alright now your apps, apps running in the cache are not always bad, there basically paused apps ready to instantly start when u want them you can use your task killer or go into running apps and manually kill them, never use auto kill on task managers, youll get issues
now your play store and such that seem to run for no reason is because your probly killing it during a process, google play, email, facebook, maps and many other apps open just to check for updates and refresh themselves, if you kill them during which they will shut off for a few minutes, then turn right back on to try and finish what you stopped it from doing before, the only 2 apps there i kill always are facebook and maps, mostly cause facebook is the only app ive ever seen in my cache thatll actually continue to eat memory until i stop it
also ive noticed, if your running a custom rom, that task killer wont always kill the program in the system, itll just stop the current process the program is doing, leaving the program itself running, in which case manual stop would be required
