Help Running Services Help GS2
I have looked at Running services and find that programs/aps that i dont use or even registered seem to be running and can not stop them for good.
Social Hub - SocialHubService
Social Hub (Email) - Z7 Service
Email (@ one) - ODEService & SmsRelayservice.
Voice Command - LMTTService & Safe Reader
Social Hub is not registered or setup.
Email is not Sync. I have samsung and google one because you have to.
Voice Command i dont use and turned it off to best i know. Even on Text Keypad. It not set up nor is drive mode selected.
Anyone got any ideas?
I got a bigger battery but the length is no different to the standard. So looking at other options.
Thanks
Thanks
These are all stock, built-in, app's and unless you are rooted you will not be able to turn them off.
It also would make almost no difference either so don't worry about it. A few idle processes have almost no impact on performance or memory use.
