Help Running services on startup like Asphalt 5?
masterz13
I checked my running services when I started my Inspire up, and there are a few pointless AT&T ones, as well as that Asphalt 5 game. They don't take up too much RAM, but is there a way (preferably without rooting) to get rid of them? I feel like they're draining my battery.
No rooting would be the only way to remove any of the preinstalled apps. Usually on start up yeah a lot of apps open run a little bit but then the system will shut them down when need be. I don't fuss with any of those apps or manually force stopping them and my battery life is fine for me. Granted its not like my captivate but i can get a good 12-15 hours of use and i feel I use my phone a lot.
