Root RUU for 2.01.601.11
Hallelujah ! Another happy Rezound owner.
Well to be honest, I was perfectly happy WITHOUT the OTA, and really if I could defer it forever I would have but this is actually better. I'd say I'm an even HAPPIER Rezound owner! Again, thanks for your help, and to Scotty85 and Scrosler as well.
And I'm re-locked and re-rooted. Only thing I did wrong was run TiBu and didn't move my backup file to my SD card...I forgot it backs up to SD internal vice SD external...DOH! Oh well...good chance to start fresh, run a NANDROID and start clean. All good.
I must be missing something. I downloaded the RUU, Ran that just fine.
My Hboot is 2.11.
My baseband version shows:
0.95.00.1118r, 0.95.00.1223r
my software # shows 1.02.605.6. I was at stock with the OTA at one point, and then flashed my nand recovory. I don't use a special rom i just debloated myself and installed apps and did TI and all that jazz. WOuld rather not start all the way over from scratch if I don't have to..
if im understanding the question correctly,the only way you could get to 2.01.605.11 without having re-set up everything is to flash over a 2.01.605.11 based rom overtop of your current setup WITHOUT a data wipe(wipe cache,wipe dalvik, cache,flash rom).
be warned,however,that some developers have their roms set to wipe automaitically,so you may boot to a reset rom anyway :eek:
also be aware that doing a "dirty flash" or "update" in this manner can sometimes lead to quirks,and small issues,so if you try it and have any small prollems,make sure you try a full wipe and re-set up before pointing the finger at a rom and accusing it of being buggy.
a clean,fresh start is the best way to upgrade,IMO. use titanium backup and the paid pro key to batch restore all of your user apps and the re-setup goes fairly painlessly :)
