shrekdroid
My friend did not have time to root my phone and simply told me to follow some directions and it ended up messing up my EVO 4G. I was working on getting revolutionary and something got messed up. I then tried to put on Cyanogenmod and it worked extremely quirky.
We ended up putting several ROMs on it and they all made it constantly bootloop.
Eventually I found a way to get it to its stock RUU rom and it still messes up. I am in constant roaming with Verizon which doesn't allow me to get service most places I go. So basically my phone is useless as a phone.
Also, certain areas of my phone screen when pressed does not work. For instance i cannot ever type the letter "s" or even activate the text box to put in names for new contacts.
Anybody know how I can get it back to using Sprint towers with no roaming and to be able to enter in all numbers and letters entry via keyboard and text etc? I basically want it to be completely stock and downloading the RUU stock ROM didn't do it all they way unfortunately.
I would eventually like to get FRESH ROM installed after I get this figured out so anybody with good directions or tutorials please share!
**********EVO 4G ***************
S-OFF
Model #: PC36100
MEID: A1000017FFE46B
IMSI: 31000913568291
HARDWARE VERSION: 0004
ANDROID VERSION: 2.2
BASEBAND VERSION: 2.15.00.11.19
KERNEL VERSION: 2.6.32.17
BUILD #: 3.70.651.1
BROWSER VERSION: 3.1
PRI VERSION: 2.15_003
PRL VERSION: 60690
HBOOT-6.16.1002
S-OFF
Model #: PC36100
BUILD #: 3.70.651.1
PRL VERSION: 60690
HBOOT-6.16.1002
