S - i recently tried rooting my A20S it wasnt sucessful
Swerv80
hello i recently tried rooting my A20S it wasnt sucessful now my phone keeps booting to the green screen PLZ HELP!!!!
The simplest fix is probably to reflash the phone back to stock firmware. You can download this from Sammobile.com, and I'm sure there are flashing instructions there (I don't have a Samsung phone so haven't learned the process myself). That will overwrite whatever you did wrong. You will need the full model number (not just A20s) to ensure you get exactly the write firmware.
If you want more specific help you'll have to tell us exactly what you did and what you saw when you did it, so someone can try to figure out what went wrong and whether there is a solution other than reflashing. Right now all we know is that you tried rooting by an unspecified method and something went wrong, which isn't much to go on. Also you would need to tell us what you actually did, not which recipe you followed (because if you didn't follow it correctly pointing us to the recipe won't tell us what you did wrong). But to be honest unless you took a backup using a custom recovery before you tried to actually root the answer is likely to be "reflash the device" anyway.
and i just want re-iterate what @Hadron said. we basically need as much info as you can provide....what is your model number? what exactly did you do? did you use a guide or website to root? if so, can you provide a link? the more info you give us the better we can help.
