Help S Note app problem
I'm not so sure that I understand why you can't do it :confused:
Open S-Note, select any of the templates and the option to attach is evident everywhere.
You might want to look for the phrase "insert" instead of attach.
You'll find the instructions under the S Note Tips within the app
I hope that helps ;)
