Help S notes is stopped
I'm always a bit worried about the fast number of services and applications that are standard swithed on at the background.
This is taking a lot of battery power and batterie working time, because when I switch a lot of them off ( ignoring the warnings) than batterie life is extended from a few hours to a few days!!!!!
Only thing now is that my S notes has a problem,don't know what
When I start the app, it starts as usual, but after a few seconds it closes down with a remark "S NOTES is STOPPED" this I can see, a second or third attempt makes no difference.
Checking the settings of the app, shows only a buttom "forced stopping", the rest of the buttons are grayed out and not functional.
Switching on some services that refer to S notes don't mak a difference
Switching off and on the device brings no change
Which extra service do I need to put on for S- notes to work again?
Clear cache and force stop S-Notes. Reboot and try again.
Android is a multitasking OS. It will put apps to "sleep" even though you may see them "running". If you are switching "off" apps, then that also may be an issue affecting your S-Notes.
Which apps are you turning off?
