shamdamdoobily
so a couple of days ago i got mine phone rooted (htc evo v). so i have an 8gb sd card and for some reason there is like 3gb used that i dont even know what it is. So im deciding on getting another sd card with more space . Would it affect my phone to get another sd card ? will it do something crazy to it ? , also im planing on getting s-off wich im a bit scared to do. i also have this beats audio installer in my phone wich im not going to do beacuse if i were to get s-off and flash mobster it is included in it i think and also many people got their devices bricked because of it . what is the risk of getting bricked in the process of s-off ? what about if im in the wire trick and for some reason i lost the wire and want to abort is it possible ? im probably going to put a 2gb sd card just in case everything gets erased and what about to flash you just go to the recovery and go to roms and select is that it ? and after flashing the rom will i get all the setting and everyhting erased or is it just when your root?
