Robtheknob7
Member
My phone is officially S-Off and Ive gotten down to this step
STEP 2: RECOVERY MODE
Hold down VOL DOWN + POWER until device boots into a White Screen.
Move to RECOVERY by using the VOL DOWN toggle and select by using POWER button.
And when I do that it goes to a orange triangle... I pull the battery and my phone goes back to normal. How do I get past this?? And if I'm not gonna use custom roms/kernals do I NEED to do the device recovery step? All I want to do is delete the bloatware and use tethering.
thanks!
thanks!
. Sounds like flyjbaker got everything covered for you. One thing, though, ROM manager has a tendency to get confused about whether or not you have recovery flashed or not, even when you do. It's usually only on a first run. So, go ahead and do what you were doing before. Boot into hboot, then select recovery. If ROM manager does say you don't have a recovery, and you do, just tell it to reflash CW. There's no harm in it. Just make sure you have CW 2.6, not 3.0.x.x. Oh, and CW now backs up your wimax keys just like RA.
