I've been using this phone for a couple of weeks now, and everyday I accidentally hit the capacitive buttons on the screen probably half a dozen times. Is there a way to disable them, and use S-pen gestures instead to do the same thing?
If you use the S-Pen to draw a < on the screen it will 'press' the back button. Drawing a ^ will do the same for the menu button. With regards to disabling the buttons, there may be an app for this...?
