Help S Pen Trouble
NoteGeek
I am new to the andoid world and to this forum.
Just got my first smartphone (galaxy note) and became addicted to the s pen:). Everything was going smoothly until one day the handwriting recognition stopped. When I write with the pen (instead of using the keypad) it no longer converts my handwriting to text.
I am wondering if I deleted something?:confused:
Any help would be greatly appreciated.
Thanx
Thanx
Hello and welcome, NoteGeek.
You're wondering if you deleted something? ;)
I'm wondering if you changed a setting in the S-Note menu or toolbar at the top.
Have a slow, careful look at the S-Note app menu and toolbar. Also, make sure you're not just invoking a template that has that text feature un-selected. I did that once and was puzzled for a bit, then found out I was not letting the default settings come back when starting a new template/document.
The other thing is to go ahead and "start over" be going into the Application Manager and hitting the S-Note/S-Pen app and clearing the cache and data, then reboot your device. That would re-set everything on those apps to their defaults. :)
