D
Deleted User
Guest
Is anyone regularly using the S-Pen, and if so how? This is my first Note and I love the phone, but I haven't found any practical uses for the S-Pen yet.
Thank you in advance.
...I have yet to work out how to imitate the "zoom"/pinch gesture on the screen without fingers on the few occasions I have to use it but I probably haven't looked hard enough.
The only downfall is that the zoom amount is preset. Both Chrome and Samsung's default browser allow the zoom amount to be changed, though (other apps may have their own settings as well, but browsers are where I find myself using zoom the most). In Chrome, go to Settings, Accessibility and for the stock browser, go to Settings, Screen and Text. Both will have a sample paragraph of text and a slider bar underneath. As per the sample text's instructions, move the slider until the text can be read comfortably, and you're done.
Thanks for asking this question. I'm in the same boat with you...my first Note and really haven't even tried the pen for anything yet...haven't seen the need.
I love the pen , feel like I'm always using it
It sucks at removing earwax. The nib is too pointy.![]()
But then it was never meant to be used as a personal grooming tool, so the S pen can't be faulted for that short-coming.My curiosity begs the question, why did you buy the Note 3 if you have zero use for the pen?
I'm not being rude, just genuinely interested in what appeals to you.
Hi new to android devices since I used apple products since. Just want to ask that when im writing using S pen in messages, it is not converted into a text message. Hope to hear some answers badly wanted to use that feature!![]()
In most text boxes, if you hover the S pen in the upper left corner, a small square with a picture of a pen will appear. Click that, and it will allow you to switch to handwriting mode. Is this the feature you were looking for?
i'm able to find the handwriting mode what im trying to say is when I start writing with the s pen it is not being converted into text message. my writings just stays there and the message field has no texts
