Help S Pen
I am rooted and on the latest Hyperdrive. When I pull the S Pen out and hover above the screen and push the button on the pen that is supposed to open the crescent S Pen menu nothing happens. What do I need to do to fix this?
Thank you in advance!
you might try asking that question in the thread for that particular ROM. they might have a fix or patch to add that back in.
I switched to Jelly Bean ROM and now everything seems to work fine. S Pen and Visual Voicemail ( which I use frequently) both work and it seems to be a good ROM. Thanks for the tip Note3Owner!
my note 3 is not rooted. I don't know if this well help our not.
Settings>S Pen>Go pen detachment>pen detachment options
*you will see three options*
1) none
2) Action memo
3) Air command
Air Command is the **Crescent Shape Thing your looking for**
Action memo brings up and memo pad where you can write freely
None >>>>surely you know what this means
That's interesting, I've used HyperDrive since it came out and mine has always launched Air Command when pushing the button.
Was there a setting or something I can tweek to make it launch AC? I still have Hyperdrive installed in slot 2 and Jelly Beans in slot 3 so I can go back and forth if I can get it to working.
Dont know it this is still relevent but, I had the same problem after looking closer in settings there is an air command menu and a slider at the top that needs to be turned on.
