Root s0l's rom (huawei support and more)
mutari
Member
ROM based on Tim's v3, but include support for huawei 3g modems.
Based on [UPDATE] UMTS / 3G Modem Support (Huawei) - xda-developers .
SOURCES!
https://github.com/s0l
Only HUAWEI devices will work!
!!!DISABLE PIN REQUEST!!!
Devices known to work:
* Vodafone K3765-H
* Vodafone K3715
* Vodafone K3565 / Huawei E160
* Huawei E173 (E171)
* Huawei E1550 (E1750)
* Huawei E1692
* Huawei E1820
How to use:
1) Flash it. Animation is _disabled_. It's mean you see only BLACK SCREEN - wait before it's loaded.
2) Insert modem. (You DO NOT NEED TO DO "AT^U2DIAG=0", but if it's not works, you can try)))
3) WAIT 15-20 secs and then go to Settings->Wireles & net->Mobile networks->APNs and look there possibly you find you'r operator (if you really wait))). If not you must to create APN by self.
4) Choice APN go back and enable "Data enabled"
5) Wait. Use 3G, send(I can only send yet) SMS and phone calls(in/out works, but do not test microphone yet). He-he. I use huawei 171 and I can do that on superpad2 )))
Throubles:
1) time to time it's drop 3g connection. solution: wait, it's recconect. if not just unplug and then plug modem. if not help just reboot (or kill rild if you know what it is). Ok, it's looks like happend on bad signal strength.
Yes, it's happend when modem switch from umts to gprs (bad signal). I am working on that issue. )
2) no sms incoming. no solution yet.
Tested with huawei 171, huawei 173, huawei 1550, huawei 1750. Wait for more testes, thanks.
HOW TO REPORT PROBLEMS:
1) reboot device without dongle inserted
2) start terminal (better term or something)
3) do: su
4) insert modem and wait while arrows stop flashing (OR TWO MINUTES IF NO ARROWS AT ALL!)
5) logcat -b radio > /sdcard/radio.txt
6) email radio.txt to me ( thetrues0l At gmail ddott comm )
7) wait respond, I will try to resolve problem
ps: s0l != sOl
More changes in rom:
1) Disabled TheatreMode*
2) Fixed flash from koti
DOWNLOAD:
http://dl.dropbox.com/u/25911995/sup...0_20110429.zip
3G support superpad2_s0l_alpha0_20110429.zip
Alternative Download Link *added by Admin​
Useful Utilities:
SD Formatter 3.0 for SD/SDHC/SDXC
http://androidforums.com/gome-flytouch-tablets/340520-sd-formatter-3-0-sd-sdhc-sdxc.html
H2testw 1.4 for detecting counterfeit Flash drives
http://androidforums.com/gome-flyto...w-1-4-detecting-counterfeit-flash-drives.html
