Help s2 battery temp. inquiry
bravo0o7
hi every1,
i've got 2 questions :
1. is it normal 4 the battery temp. to go high (around 44-46c) during recharging or is there something wrong?
2- how to reboot the battery when the temp. is too high?
thanx, i appreciate ur help:)
That's pretty warm unless the ambient temperature is really high. I've never checked my own while charging but it only ever feels slightly warmer, even after a few hours on charge. Does this happen consistently and is the handset noticeably warm to the touch? If so then I'd suggest there's an issue with it.
Just remove the charging cable.
how do u know the exact temp, are u using a good battery temp monitor app? maybe the app is wrong :D norton utilities is a good app, it shows ur battery temp, give it a shot n see if ur battery temp is often this high while charging.. mine never feels warm, only slightly
