S2 Boost Compatible ROMS?
ModifHigher
I tried a few select roms from the epic touch 4G section.
They all bootlooped.
Im on GC01 JB and I have agats custom recovery/kernel installed.
Where can I find any good roms that are compatible with our phone?:(
I ended up doing that.i flashed the EL29 Directnoot kernel/recovery and everything eas fine after that.i was nervous to follow the direct instructions because i was afraid itd bork something.
It's what I use to flash everything. Any ROM in the E4GT section should work just fine for it's Boost brethren.
I use the Agat recovery for just normal everyday nandroid backups. For flashing to another ROM, I always follow the install instruction from the original post for said ROM, including which recovery kernel to use for flashing it.
