fillerfine
I've bought a Samsung Galaxy S2 and am having a lot of problems with it in regards to battery consumption, and it's making me regret buying this phone.
I can play games and have a call on loudspeaker and the drain on the battery seems more than fine - but on standby the battery is just draining like I'm using it all the time. I'm scared to touch the phone to be honest as it barely lasts 15 hours on standby, this is with GPS off, Wi-Fi off, and roaming Internet off, brightness on lowest possible (which is not low enough IMHO). The phone is also on Economy mode and I have used "Battery saver" software, none of which seems to work. I lose about 25% power overnight with everything switched off on standby which is ridiculous. I don't want to have to switch my phone off in case I get a call and I use it for my alarm. Please can someone help, I am having almost Obsessive Compulsive behaviour towards saving the battery. I have an iPod Touch 4G and when not in use - it never drains with Wi-Fi on or high-res backgrounds, so why should this be any different?
Here are more changes I made to save the battery, all of which fail to save any power;
- Black background
- Lock wallpaper is low-res black background
- Deleted all widgets
- Removed auto-refresh on Facebook and other apps
- Regularly cancel all tasks in Task Manager
Why is the battery draining this much when I'm not using it? To me this can't be normal and I don't want a phone which I have to charge all the time and keep turning things off. When you disable all of the above, there isn't much point in having the phone.
Any help would be appreciated.
