Help s2 running really slow?
Any one having similar problems? Its taking a while to response to most tasks.
not here. like what tasks?? :). the only delay which im sure everyone has is when u move from say the last screen to the main home screen using the home button. u get a slight delay which is bad for a dual core phone. my nexus one is quicker at it. apart from that..... its a good phone :P
I sometimes get a delay opening dolphin browser, there is a 2-3 delay then the browser opens then when you touch the screen the fade/ zoom effect occurs then all works ok.
have you checked your running applications that may somehow be the cause of high CPU utilization? if totally none.. i think you should bring it back to the store for checking .. afterall that's the warranty all about :)
You have to take into consideration that android right now is not programmed for dual core phones so theres no multi treading support... I suspect once ice cream sandwich comes it will get A LOT faster. However even as the phone is now its quite fast to my standards with maybe a few areas where it could be made faster like the wake or return to main home screen.
