Hi all
Having a problem turning my S2 off......I press the side button and choose power off and then ok.....phone then shuts down but about 20 seconds later come back on.
If I take battery out.....and replace I get a screen toggling between a flat battery icon and a half charger battery. (have tried and replaced battery so that's ok) The only way I can switch on is to start charging and then turn on and phone and it will boot up ok.....fine if I am at home not so good when out and about !
Has anyone else had same problems and can recommend a fix...
Appreciated any help and thanks for your time
Regards
Mike
Regards
Mike
