Palmetto Fellow
Android Expert
So for the first week or so I've been following my battery performance with battery monitor widget. I noticed that when sleeping it would draw only like 15-40 MA for the most part. Using the phone with the screen on would draw 300-400mA. If I used navigation and left the screen on, I could draw up to 1000mA.
Today I switched to the Gorilla Gadgets 4500 mAh battery. I was drawing 400mA while sleeping at times, and eventually it dropped to like 38mA when I got home and got on Wi-Fi. Maybe my signal was low and that's why it drew so much current.
Just a few minutes ago, I started using my phone and in less than 5 minutes, it went from 38mA to 1388mA draw. This is unprecedented.
I can't figure out how a different battery would cause the phone to draw so much more current. Do you think battery monitor widget could be wrong? Had anyone else noticed a major increase in current draw after moving to an extended battery?
I also rooted but haven't installed a custom ROM since putting in the battery.
