Help S4 Low Media Volume
Yeah, I've had volume issues since day 1. Are you rooted? If so, try this - it worked for me:
http://www.droidviews.com/how-to-increase-speaker-volume-on-your-rooted-samsung-galaxy-s4/
If not, I suggest using Audacity to boost the volume of your ringtones (ones you did - not the stock ones). I did that too and it really helped. Its really easy - research it a little and give it a try.
If you want some loud ringtones, try these - they are really loud and work well for those of us who are not rooted:
[Ringtones] Very LOUD ringtones. For noisy environments or ppl with hearing disorders - xda-developers
Hope this helps - Happy Holidays!
