s4 not working properly anymore
davepenn
hi guys. i have a galaxy s4 that has started to act up.
it is not under warranty anymore as ive had it more than 2 years. about 4month ago i cracked the screen so took it to a phone shop and they replaced the screen for me
i have a rubber case for the phone as i regularly have dropped it a few times, im wondering if this be something to do with the problems
it has not been rooted and is on 4.4.2
the auto rotate only works for a short while then it stops working all together, but if i restart the phone it works ok but not for long.
it is starting to feel sluggish when using the phone. ie swiping and pressing buttons and apps
it randomly freezes and restarts itself.
i have factory reset the phone and done a wipe cache
but it still continues.
any ideas or help would be greatly appreciated
and wether you think it is worth paying to get it fixed
When you say they replaced the screen, are you referring to both the LCD screen and digitizer or just one of them? If they dand replaced both as one piece, I wonder if they replaced it with the correct Model # assembly. You can verify this by opening up the back to see if the numbers match. Check out this video.
