I can't seem to find a "simple" answer to this anywhere...I want to switch to the Samsung S4, but I have a mac and no one can tell me if it's compatible and how to transfer music etc to the S4...
thank you in advance
I've had one or two "device not recognised" issues but rebooting the Mac always solved them.
.For android file transfer to work on your mac make sure you uninstall kies with via the install process,not just move it from the apps folder to trash. Worked fine for me doing this.
After that I just copied all the music onto the sd card.
Calendar, notes and contacts all sync up we'll from mac to google too
