Lanman1978
I am currently running the newest Midnight ROM at max 1.5 GHz and min 648 MHz. My question is this a safe range to stay in? I am only maxing out at 300 MHz over stock so I don't think I am pushing it too much.
Its going to be different for everyone's phone. You'll know you went too high when you get random reboots and bootloops
As an example, my evos stock clock speed is 1.5.. I can over clock it all the way to 2.1, but others with the same phone can't get above 1.9 without issues.
I have been running both cores at. 384 min and 1.512 max on performance Governor. I have no issues. Battery life isn't a concern. I have the best extended battery. It makes my phone thick. But it doesn't bother me...... http://item.mobileweb.ebay.com/view...1125209037&index=0&nav=SEARCH&nid=29472659982
Trust me guys. You won't find a better extended battery. Not the cheapest option. But you get what you pay for. I get two days without being a charge. Even at my overclocked cpu settings
Why on earth would you ever run on performance?
Seriously, this. The only time I ever run on performance is if I'm doing a benchmark for some reason.
Performance makes the CPU always run at the maximum specified speed. Just like powersave makes it run at the lowest.
That extended battery will last a hell of a lot longer if you use ondemand, interactive, or basically ANYTHING else
I run performance because I want performance.![]()
Your phone isn't built for thatI run performance because I want performance.![]()
Use interactive or smartassv2, 192 min and 1.512 max, with a screen off profile, 192 min and 384 max. I guarantee you won't notice a difference in performance
BTW from this site and xda
androidforums.com/xperia-mini-all-things-root/513426-android-cpu-governors-explained.html
3: Performance Governor:
This locks the phone's CPU at maximum frequency. While this may sound like an ugly idea, there is growing evidence to suggest that running a phone at its maximum frequency at all times will allow a faster race-to-idle. Race-to-idle is the process by which a phone completes a given task, such as syncing email, and returns the CPU to the extremely efficient low-power state. This still requires extensive testing, and a kernel that properly implements a given CPU's C-states (low power states).
forum.xda-developers.com/showthread.php?t=1856256
5. Performance: It has the same min and max frequency so I guess your phone will heat up and throttle really quick, although if you want to benchmark this would give you the best result.
. well you are probably right. I have since switched to xondemand. it seems all right.running at max performance all the time sounds painful to the CPU..
