Help Safe Mode Keep Turning On
Lana30
Hi Friends,
A friend of mine keeps complaining that she wants to disable safe mode forever, ha ha, because it keeps turning on by itself I guess. Any guesses as to why it does this and how to stop it? Thanks.
They likely have a stuck volume key/rocker and/or the power button.
It's more likely to be the stuck volume key/rocker...have them check to see if it's dirty/gummed-up and stuck in one position and see if that helps.
I will tell her about your suggestion, Thank you. I will keep you posted on what happens.
