Help Safe mode messes up all my widgets
Hawker
Android Expert
I tried booting up into safe mode (to see if I could)
It loaded up my standard screens minus live wallpaper and widgets
Now when I boot up normally, my live wallpaper is no longer set (not a biggie) but ALL my widgets are now filled with "problem loading widget"
Short of deleting and recreating them on my homescreens, any ideas on if there is a quick way to get them back?
ok i tried spamming home button as soon as power is on
i tried holding down home button as soon as power is on
i tried a combination of spamming and holding down
no safe mode
lol should i keep trying to load safe mode?
anyway do u have to be rooted to go into safe mode?
if you would read info of hawker you would spot (otherwise ur blind) that hes NOT rooted.
and back to topic... did u make any backup before that ? i`m rooted now and i use titanium for that but in your case i`m not sure i can help you :( i`m afraid u will have to set widgets once again from start.
no safe mode
thats cos you need to press the MENU key!
oh well, now you have it... i guess that setting all widgets again can be pain in the ass but theres no option left.
Offtopic
i`ve checked your website and i`m impressed with your celica :) just tell me why the hell you changed such a lovely car for mazda 6 ?
will everything be back to normal once i exit safe mode?
no, it wont! do you actually read with understanding ? read once again fisrt post in this topic what happened to hawker after getting to safe mode...
DOH! I suggest you read this thread!
Offtopic
Thanks mate! My little boy was born, so I needed a bigger car to accomodate the family. I loved that Celica. Did loads of work on it, but family comes first butty!
I've deleted them and re-added them now.
What a PITA!
Thought: I'm using GO Launcher, so it may be due to this, or it could be a general problem.
Need someone else to give this a go I suppose!!.... (go launcher AND touchwiz people)
offtopic
that was only reason which appeared in my head, new family member :) i assume u dont have Celica anymore ? :( i`d love to to get my hands on it :D absolutley stunning car!
i did exact same thing with the menu button ( the softkey to the LEFT of home screen button) and still no safe mode
most of the time during boot up the menu key didn't even light up so i doubt it had any effect when i press or hold on it
why on earth u want safe mode if you dont need it ?
offtopic
No, unfortunately its gone, but it went to your neck of the woods Bart (Sligo)
Once the graphic has started to show on bootup, keep fast-pressing the MENU key until you see "safe mode" appear in the bottom left of the screen.
Be our guinea-pig! Tell us what you lose!
err how fast do i have to press?
i'm already spamming it as soon as i turn power on
ONCE THE GRAPHIC HAS STARTED TO SHOW
Ie. the animation splash screen
UPDATE: All buddy widgets, clock, bookmarks and accuweather widget remained unaffected.
This problem seems to relate to non-rom (ie 3rd party) widgets
well im in Cork but maybe i will find it somewhere :) i`m about to change a car and as i dont have kids yet it has to be a coupe (fast one) :D
and coming back to topic. im using laucher pro but i will do backup l8r and check safe mode and tell you whats the results :) i`m bit busy here and dont want to mess up my widgets atm cause it took me some time to set them the way i like... but i ll check it l8r
UPDATE: All buddy widgets, bookmarks and accuweather widget remained unaffected.
doesn't matter
i spammed/hold all the way till lock screen loads and scanning media appears
no safe mode
k i just managed to get into safe mode but i had no widgets on
i'm gonna add a couple widgets and go back to safe mode again to see if it'll show error
