Safe Mode - on two SGS2
fontburn
Member
Hi,
Something odd happened to my Orange UK Official 2.3.5 over the weekend. I was taking some photos and locking the screen between shots with the camera app running. After a while I unlocked the phone and the phone froze up and then dropped to the home screen. The home screen was blank, only the stock icons on bottom and the words safe mode written on the bottom right. Thought it was odd but after a battery pull (nothing else turned the phone off) all came back.
Now the odd bit.
In my application window I have 10 screens of apps. After the battery pull fix I had 16. On 6 screens only one app icon was showing. So after some moving them all back to the right screen I was back to normal.
Now it gets odder.
My collegue has an unbranded phone on stock 2.3.4 on different network, he had the same thing happen to his phone over the weekend. Exactly the same issue.
Did google or samsung send an OTA update out to comply with anything ?? Or freaky incident.
I've not seen the phone go into safe mode by itself before.
you can boot into safe mode by powering up and when you see the GS2 screen graphic repeatedly press the menu button quickly until you see the home screen. You WILL lose icons by going into safe mode, in particular any homescreen widgets, which seems like what has happened to you
As to why it went into safe mode by itself is another matter.
