Safe mode reboot
justjimjpc
Premium Member
This procedure can clear a large number of problems and should be tried before a Hard Reset.
1.) Turn phone off ... remove battery .. WAIT for at least two minutes.
2.) Power On Phone while Holding MENU key ... Until ALL actions finish from Powering on phone ...
....... At the bottom left corner of the display in transparent text will be the words "Safe Mode"
3.) Power off phone again ... battery out ... wait two minutes
4.) do a normal power on ...
I have a little problem. I can't run it in safe mode...
Or I just don't have the words "safe mode".
I wanted to run my G1's in safe mode cause of my alarm clock. It doesn't give me any sound.
The other sounds like my ringtone or sms notify works great.
Sorry for my english :)
You Need to hold the "MENU" key for a long time ... to make sure that none of the normal background programs get loaded into memory ...
The Safe Mode words are very light (transparent) in the lower left corner of the screen ....
So start by holding down "MENU" key then press Power ... continue hold "MENU" key until you see the "Safe Mode" words on the desktop screen.
Note if there are apps that you want to run that normally run at startup ... you will need to run them after the boot-up ... by selecting them manually ..
