F farfromuman Newbie Dec 22, 2012 #1 I want to change WiFi scan interval and screen dpi, is it safe to edit the file or will I get any errors?
Connorh333 Well-Known Member Dec 29, 2012 #2 You can change the build.prop. I just wouldn't change The android version.
Sakib Well-Known Member Dec 29, 2012 #3 Yes, Totally Safe just Don't play around with the build.version ... !
LDrifta No Stranger 2 Danger Dec 29, 2012 #4 changing dpi sometimes makes it so you cannot download apps from market so be carefull
F farfromuman Newbie Dec 29, 2012 #5 Thanks for the replies, I noticed the wifi scans every 20 seconds, seems a bit excessive.
Sakib Well-Known Member Jan 1, 2013 #6 DPI dosen't interact with Play Store .. And you can Change the Timeings to your Choice!
