Root Safe to format SD card after root?
edgrlon
Will it F up my phone or not? There's a lot of junk on my SD card and I just want to format it so I can get organized. :cool: If it's not safe, then is there any apps that I can use to clean the junk off my card? Or does anyone know what NOT to delete? :confused:
Thanks
-edgrlon:)
I would only worry about the Nandroid backups you have. Other than that, nothing there is crucial to the day to day running of the phone. You will be fine to format it and clean it up.
You know you can transfer all the files you want to keep to your desktop, right?
