I am currently using safestrap to run an ICS rom on my safe system. However, when I installed safestrap, I believe I wiped my non-safe system, thinking I was on my safe system.
Now, when I go to my safe system, I assume there is no /system and I need to install a new rom or something, but you cannot use the install zip function in non-safe mode.
Might I be mistaken about what I did? If not, do I need to sbf to get back to normal or what should I do?
