Samsung 2000mah bat & Otterbox Commuter fix
led hed
hey folks, i have the Otterbox Commuter case and the 2000mah extended battery.
we know they don't fit well together, stock.
what i did:
took rubber insert, cut the flat back out to make more room for the new the new 'thicker' back cover. if you look at the Neo Hybrid Ex, i cut the back to look similar. in essence, making a 'ring' out of the rubber insert.
works great! and i get to keep my otterbox.
