Root Samsung Admire for nTelos
ironmask
Looking for a stock ROM of the Samsung Admire for nTelos... Seems that when I chose to use the custom ROMs that are currently out there it disabled mms messages... regular texting is fine, mms and large text messages do not send... so I am looking to try and fix this... Anyone else out there have one?
Thanks!
I know this is not an answer to your question but I just got this phone and was concerned about rooting due to it being Ntelos. Did you root yours successfully? If so can I one click mine then possibility backup the ROM, then copy and send.
Yes it rooted fine... Just follow the root guide:
http://androidforums.com/admire-all...e-sch-r720-windows-mac-linux-9-12-2011-a.html
..and then use my instructions on how to put CWM (ClockworkMod Recovery):
http://androidforums.com/admire-all...ckwork-recovery-mod-install-instructions.html
That way after it is rooted.. you can install the custom ROMs being made for this phone so it will run smoother, etc.
Have fun and good luck! :)
Change your APN settings to these values
nTelos
NTELOS **THESE SETTINGS ARE CONFIRMED WORKING**MANY THANKS TO JWnSC**
APN Name: USCC
Numeric: 31000
MCC: 310
MNC: 00
APN: USCC
User: USCC
Server: *
Password: *
Proxy:
Port:
MMS proxy:
MMS port:
MMS protocol:
MMSC: http://mms.ntelospcs.net
Source::
[TUTORIAL][AOSP] US Cellular,C Spire, NTELOS MMS APN Settings - ALL - RootzWiki
Thanks alot bro, I will try this as soon as I get the chance! :D You are awesome!
I tried the method and still can't get it to work... someone want to build me a zip to flash through CWM?
