Samsung Admire (System Dump).zip
This is just a System dump pulled off of a STOCK rooted Samsung Admire [2.3.4]
essentially has ALL System files. Alot of people have been going crazy deleting system files and finding no way to replace them . Just simply extract and pull/push any file needed thru adb shell or using Root Explorer.
Hope this helps. I had posted this over at SDX but this is currently were most admire fans reside . So it'll be of more use for you guys.
Hope it helps.
Hope it helps.
so hope everyone can find this helpful.
Not that I use it cause I'm a launcherpro guy lol But would be useful if I need to do a factory reset aka setup wizard needs that launcher! Thanks in advance! Joe
