Help samsung admire wont send picture messaging
After i updated my prl for 3G service my phone wont send picture messaging can anybody help me???????
You updated your prl manually via qpst?
If so update through the metro system, you put a prl that doesn't correlate to any towers near you.
I'm having the same problem with my MMS messaging. I used to have the Handcent app installed and it used to send MMS messages perfectly fine, then it pretty much stopped sending them. Now I have Go SMS Pro installed instead and it sent one MMS message, and now nothing. I can send MMS messages perfectly fine from the stock messaging app, but none of the downloaded apps. I have no problem receiving MMS messages from both the stock & downloaded messaging apps. Anyone know what the problem is??
Did you guys remove MMS by chance? This will cause you to have picture sending issue. I rooted my phone, and Im seeing what I can and cant do with the help of tokenpoke..
