23archivist
IDamn I'm a bastard now!!! [emoji12]
I downloaded the thread and installed and went into a bootloop. What am I doing wrong
I
Yep, followed the directions downloaded both zips, wiped everything but the internal and flashed....did ya try wiping cache?
Was the download bad? I need more info then it just I download and bootloopYep, followed the directions downloaded both zips, wiped everything but the internal and flashed....
So are you in a bootloop or you're settings is fcIt says "unfortunately settings has stopped" and won't allow me to proceed
You didn't clean installI can actually see the sign in accessibility page but that's where the error message pops up
OK I'll try again now. Good lookin.I'm not in the bootloop
So you said you were in a bootloop but now you're not and your setting apk is closingI'm not in the bootloop
Good luck man aopk is already rooted.OK so I did a clean install and got to a point in twrp where it said my device does not appear to be rooted. Although it is. Is asked if I wanted to install su I tried both ways, to install and not to install. I was held hostage by the boot screen for about 5 mins before I abandoned. Is there a reasonable amount of time I should wait or am I missing something
Glad you got it work I was in the middle of somethingGot it! !!!!! Installed third party app to assist. Thank you for your patience.
You have to set your time zone manually sorryQuestion: my clock jumps back about 5 hours on its own. Got any ideas
Yeah I've tried that setting thing doesn't work and I've been able to screenshot for about 2 days with the ROM and then one day it just stopped working and said that message my phone goes really slow now alsoThat's a setting you can turn off in your wifi setings, the storage in use deal means that whatever you're trying to screenshot is coded to not let you screenshot, it's DRM protected
