If you're talking about the single bars. It is a overlay issues I never fixed there is a lot of cosmetic stuff I didn't fix and I'm not supporting either of those rooms anymore that's why I took them down. So you pretty much get what you getAnyone know why the quality drops when I flash cm or aokp rom?
If you're talking about the signal bars. It is a overlay issues I never fixed there is a lot of cosmetic stuff I didn't fix and I'm not supporting either of those rooms anymore that's why I took them down. So you pretty much get what you getAnyone know why the quality drops when I flash cm or aokp rom?
If I was one hell of a developer I would be working at Google!!! I'm just mediocreYou're a hell of a good developer or whatever title you carry. People are critical of everything but themselves. Some respect your craft and contributions. Please assist those who call on you for your skills. You are DFUSE.....
Hahahaha developer none the less. HEY GOOGLE DFUSE WANTS A JOB!!! Lol. But again thanks for your contributions. Remember, you inspired me to flash my first rom. HahahahaIf I was one hell of a developer I would be working at Google!!! I'm just mediocre
Well I appreciate it man. Idk if you know or not but I have a twrp 2.8.6.0 on my filehost there is 2 difference zips one has USB otg enabled. Also you might want check me out on g+. From now on all links will be posted there.Hahahaha developer none the less. HEY GOOGLE DFUSE WANTS A JOB!!! Lol. But again thanks for your contributions. Remember, you inspired me to flash my first rom. Hahahaha
Cool. I'm there. I'll be in touch. Stay upWell I appreciate it man. Idk if you know or not but I have a twrp 2.8.6.0 on my filehost there is 2 difference zips one has USB otg enabled. Also you might want check me out on g+. From now on all links will be posted there.
Edit your build prop to 4.4.2 on the android version. That's something android didNo I mean like before I flashed this rom videos would play like 480p on YouTube and some other apps but now it just like plays 360p and under
You probably can use that idk I been using root explorer for 5 yearsHow do I do that with es file explorer
Do I need twrp to get cm 11?Make sure you're rooted (obviously) and read the description: https://play.google.com/store/apps/details?id=com.dfuse.avantexploded
You need a custom recovery. That could be TWRP, CWM, or PHILZ.Do I need twrp to get cm 11?
Ok kool. As you can tell, I'm a noobYou need a custom recovery. That could be TWRP, CWM, or PHILZ.
Naw I couldn't tell bro. [emoji12]Ok kool. As you can tell, I'm a noob
