BrokenAndroid
Okay, No one believed me in my previous thread, so here is the proof. Below is an email sent to me by Samsung Australia when I asked them about a ****-up they did with the latest TouchWiz update for Android 4.0.4.
The problem is, I can NOT add or change the apps in my favourites dock at the bottom of the phone screen. Their ****ing solution is to hard reset the phone. As you can see by their email, they admit that there is no way to change the apps on the favourites dock anymore...
Dear xxx,
Thank you for contacting Samsung Customer Care.
I appolagise for any inconvenience this has cause you.
This is a new feature of the Galaxy S3 Android 4.0.4.
If you currently have an emtpy space in the dock we will be able to resolve the issue by resetting the operating system using our Hard Reset procedure.
You will need to reset your entire device back to factory default using our Hard Reset procedure.
A Hard Reset will wipe all data on your device and re-install a back up operating system which is stored on your internal device memory.
You will need to back up all user generated data before performing a Hard Reset.
To back up your handset with Samsung Kies you will first need to install Samsung Kies, below is a link to the latest version of Samsung Kies.
http://www.samsung.com/au/support/usefulsoftware/KIES/JSP
If you already have Samsung Kies installed you will not need to download Samsung Kies again.
Once Kies has been opened on your computer you will need to plug your handset into the USB port on your computer using the cable which was provided with your handset.
Once the device has been plugged into the computer you will need to left click on the model number under Connected Devices on top left hand corner of Kies.
When you have clicked on the model number you see four options on the right hand side, Basic Information, Sync, Backup/Restore and Import/Export. We will need to select Import/Export.
Import/Export allows you to export files from your handset to a location on your computer of your choosing.
You can also use the import feature to import files from the computer onto your handset.
To perform a Hard Reset you will need to Dial *2767*3855# into your keypad just like you would dial an ordinary phone number. The handset will restart and turn itself back on automatically. Once the handset has completely restarted the handset will be ready to use as normal.
If you have any further enquiries, please do not hesitate to contact Samsung Customer Care on 1300 362 603.
Thank you for contacting Samsung.
Kind regards,
Kieren
http://www.samsung.com.au
Dear xxx,
Kind regards,
Kieren
