Help Samsung Captivate Battery Problems
V
vinnyb07
Guest
The battery on my Samsung Captivate is horrible. I will only get a few hours of normal use (which is texting and maybe a few calls).
I am running Firmware version 2.2
Battery Usage:
Display (95%)
Wi-Fi (3%)
Cell Standby (2%)
ALSO, I have the brightness set all the way down to zero, and have power-saving mode on.
Could it be a hardware problem?
One thing that seems to work, is to let your battery drain all the way down- to nothing if you have the patience- and then charge it completely. This helped when my battery was not giving me a full days charge. Looking at your usage, your display is using a lot of battery. Mine normally runs around 51%. Are you using any widgets? Any live wallpaper? They can be battery hogs.
