Hi all, I've been lurking on these forums and finally decided to post after a failed attempt to use odin (in order to flash Assonance). At the time I used odin, my phone was fully stock and was not rooted.
I turned on USB debugging on my captivate, put it into download mode, and pressed "start" on odin. All seems fine and dandy. However, the phone is now in a constant reboot loop - when unplugged, it goes to the white AT&T screen and then reboots. When plugged into the wall or the USB, it shows the battery charging screen and then reboots. I cannot get to the main OS screen.
I've tried the various methods described in how to get the phone back to download mode (the 2 and 3 button methods, as well as switching up the steps described) but have not yet had any success getting my phone out of the reboot loop and back into download mode.
Does anyone know what I can do to get my phone back to working condition? I've read on other sites that I may need to build a USB jig? Is this my only solution, or are there other methods that I have not yet thought of?
