Samsung Captivate Multi Sync Options
lowtaren
Hi All
I've been looking around this forum to try to answer some pre purchase questions regarding the Captivate's synchronization options.
Will the Samsung Captivate maintain separate Calendars/Contacts if the following accounts are all synced to the same device: One MS Exchange account via Exchange ActiveSync, One MS Outlook Profile via Samsung Kies.
I currently use an iPhone 3GS and it syncs everything up nicely while keeping them separate: Exchange Contacts, Exchange Calendar, Outlook (from your computer) Contacts, Outlook (from your computer) Calendar.
I'm also a Google Voice user, does the Google Voice app for Android use Exchange ActiveSync to pull Contacts info? Can the Google Voice app dial/text Contacts that are only on the phone and not in Google Contacts?
-Thanks!
