Help Samsung captivate soft reset loop
mudcup
I bought jailbreaked samsung captivate, and i inserted my carrier sim card. just start up, phone starts to slow down , and soft resets itself, then starts i can enter home screen but again goes to soft reset.
Without inserting sim , everithing ok.
Then i go home, connected to internet with wifi and inserted sim card again... no problem, it worked. then i switched off wifi, yeah it was working so...
in the morning , i go to work, then same problem occured.
some part of the parking area is out of carriers range, so service was un available at that time, after entering service available zone, phone started to do that.
it seems to me , when phone stars up , it is looking for connection or sth, then it enters into soft reset loop,
pc: ive disabled auto update tima and date, no change , problem still there.
. any suggestion ?
edited: When i cange location it just worked fine. It seems its about modem(radio) issue. My base band version: I897UCJE4
