Samsung Captivate
Ferrellra
All,
My iphone 3gs was stolen yesterday. I ordered a new Samsung Captivate with AT&T. I have been looking around online and Samsung says that the software that comes with the phone is not compatible with MAC computers and their OS system. Does anybody know anything about this or a work around?
Regards,
Rusty
rustyandnilsa@gmail.com
It's very easy. Just go into settings>Applications>Development>and check USB debugging. Then plug your Captivate into the computer and on the notification bar you'll find a USB marker. Click it and it will ask if you want to mount your device. Click mount and you're done :)
