samsung epic 4g
it was already released 2 weeks ago but it was recalled cause of bugs. no new release yet. you can get the 2.2 update here on this site. just search for it!
pflol ur a lucky individual .... as lucky as the ppl that claim they never have had an issue with the epic keyboard .... i.m.o. eb13 sux & not only because of the changes made which takes getting used to . . it wasnt stable .... i will say i did the update.zip way not the 200mb upgrade & i did hard reset also . . back to 2.1 & its A ok with me lol
eb13 is pretty stable on our epic too. The only problem we have with it is an occaisional lockup when we plug it into the charger that needs a battery pull to wake it back up. Everything else works so good though that we're dealing with it until I can figure it out.
Fwiw, I did the 200mb flash upgrade method.
I still have yet to encounter any bugs with the first release of eb13 ;\
take a look at your call logs - try to get only calls not messages - thats a problem
there are many other problems just do a simple search here and you will see many people having all sorts of problems that didnt exist before
I don't like the change to the call log, but I rarely use it so it doesn't really affect me like it does others.
