If you already have the drivers installed, try using a different micro usb data cable, the one that comes with the phone isn't the best (any micro usb to usb should work fine). If that doesn't work you can try it through a different usb port on your computer.
Moving to the Epic 4G forum, and PM'ing you so you know where to find the thread
