I tried to put JTs on the phone. When it started it said conversion failed and just hung on the screen that said Samsung with the number of the program next to it.
So i put it in download mode and put clockwork back on it and restarted. It just blinks samsung when i start it.
So i did it again and this time i cleared the cache and reset it to factory. The phone goes through the motions and says everything is set. I restart it and it just blinks on a black screen, samsung. Did i mess this thing up?
It allows me to get in the system / download screen and do what i want. I am missing something
UPDATE.
I try to back up from my SD it loads all the info from recovery zip. i choose the image to restore clockwork mod recovery v2.5.1.0
and then it checks MD5 sums.
restoring system...goes through files
at the end it says..
cant ount /dev/block/mcblk0p2
file exists
cant mount data.
UPDATE.
file exists
cant mount data.
