Samsung Galaxy 2
Roobie
So i got a samsung galaxy 2 like 2 months ago. I went on vacation and my phone fell inside the pool. At first my phone was acting up but now its perfectly fine and it seems to be normal. Now I've tried to connect my phone to my mac computer through the usb wire that i was given with the phone, and it does not work. I don't know if its because my phone is water damaged or I'm not doing it correctly. But i've been to settings and turned on the usb debugging box under development and the unknown sources box under applications but it doesn't work. CAN SOMEONE PLEASE HELP !
Well you need to install the phone drivers on your computer first.
But if you dropped your phone in the pool even though it works, I would start looking for another one soon.
Robbie, welcome which Carrier are you on, so I can direct you to your device forum and get the proper support.
Welcome to the forums Roobie. :hello:
Download and install Samsung Kies. It will install the latest drivers you need. Then plug your phone in and see if it works.
