Help samsung galaxy ace 2
hayhay14
Hi i have a samsung galaxy ace 2 and when it comes on and even when its on it as these grey lines coming down the screen and then the phone freezes please help
Hi hayhay14 ...
Welcome to Android Forums.
I would suggest doing a reset of the device. This process should help to fix any software issues that might be caused by any installed application(s).
However, if the device has any hardware problems -- this troubleshooting step might not be able to resolved the issue....and you might need to have it checked out by a technician.
Good luck. ;)
Thank you for your help ill try reseting it and see if that works and if fails ill take it into the shop and have it looked over xthanks again
