Help Samsung Galaxy Ace II camera
Hi
I take 11 photos on the camera and the memory is full!?
I have stored about 750mb of music otherwise I have not added any new devices or stored any other data on the phone.
there doesn't appear to be any means to reduce pixel size, surely there is sufficient memory to store dozens of photos?
I've discovered under the settings menu there should be a option to alter the storage location, however this option is very dull and cannot be opened!!??
Any help would be most gratefully received.
Cheers
Andy
Well, you don't have an external SD card installed if you can't access the option to change storage. Buy an SD card and insert it into the phone. The Ace 2 has only 3GB worth of intenal memory with almost 2GB of that reserved for app installations, leaving you with a about 900MB of storage for pictures and music/media, unless you buy and insert an external storage card. Get a 32GB one if you want.
Well that's news to me, thanks very much for providing insight , having gone thru the user handbook and various other bits of info that came with the phone I hadn't learned that this was necessary, possible, worthwhile - amazing really
much appreciated
regards
andy
